KWIK CONNECT LUBE?
Ne
I have been using WD-40 but is it better to use a silicone spray?
Cameron1
Jimmy,
judging by that picture under your name, I would just use what that robot uses while he is taking advantage of you.
Ne
But Steve did Joe P use any lube on you or didn't it hurt ?
Cameron1
Nope, none needed !! Joe was too busy lubing up all the un-ethical cleaners to worry about me.
I got a feeling though, that when he sees you in that Star wars suit he's going send the Jedi over to see you, with instructions to not use the lube this time. Then he's gonna tell the Jedi to keep at it untill you get ethical.
Ne
I heard he did bad things in that car you won from him.
Shawn Forsythe
Parker O-Ring Lube is the best I've seen.
Huskey "Lube O'Seal" is pretty good too.
These two have a viscosity and a cohesive bond that second to none. Both products stick around a while, and have a strange "stickyness" that has to be seen, to be understood why they work so well.
captaincarpet
Kennesaw Ga.
Thomas Cermak
Shawn
Thanks for seconding the Parker O Ring lube, Few people know about it, but its very good.I've been using the same tube for 2 years because it takes so little and lasts so long.(we apply it with a Q-tip)
