Leaking radiator
shagman
Im having problems with excessive vibration with my Prochem Apex diesel and have split the seams on 4 radiators since 2005 . Im looking for a used radiator ( leaking or not ) for this unit so that I could have a high performance shop build a heavy duty replica of it . Im a one truck operation and dont want the down time of pulling the existing one out . I would appreciate any advice , Thank you .
You can also change out the belts ( except the blower) to the link style. They will help some. Also talk to a radiator shop about possibly mounting the new tank on rubber isolators instead of direct bolting to frame.
Gene
shagman
Thanks Gene , I will certainly modify with some rubber bushings to reduce some of the vibration .
