Leftover Prespray
lesterj2
I was wondering when Im finished with a job what should I do with the leftover Prespray after Im finished...
Would it be fine to put it into an old glass pickle jar, LOL... Or just buy a 1 gal. plastic jug and store it in a cool dry place...
I reuse my prespray. I mix it in a 2.5 gal battery sprayer. I just fill the container the next day and add to it. If I use powermax I just add what I would for a whole bucket full to make sure it has enough O2. Although often times I try to spray the rest out in the trashed places if I can.
If I had a inline sprayer I wouldn't dump it either. Chems cost too much to throw out and they don't go bad only peroxide goes bad from what I understand.
I do too lester. I don't think it goes bad unless you have something heavy with peroxide in it. It don't hurt to put a top on it. The omni jugs have caps. And hydroforce sprayers have caps available too. If you're using a pump up, you already have a cap in place.
Rex Tyus
Like TimP and Meat said, it depends on what type of prespray you are using. Some are good for a couple of weeks. Some a couple of hours. If it is not heavy on peroxide or sensitive enzymes you should get some decent shelf life.
lesterj2
well im using some Powder Extraction detergent called CarpetCop... and i like to add like 3 oz. 4o wt. Peroxide...
Rex Tyus
If a prespray needs peroxide on a "regular" basis to get good results it is time to consider a new prespray. Peroxide should be used after cleaning to get what the detergent won't get. Not to bleach instead of using a good detergent and cleaning. just and opinion. I know this is contrary to the common opinion that is the flavor of the month but it is my OPINION. Clean it first. Then oxidize as needed.
joey895
Florida
Joey J.
I agree. I generally only add peroxide directly to my pre-spray if there are urine issues and on olefin berbers.
Arizona
I carry 20 gallons of RTU's in the truck ..so at the end of the day I pour what is left over into my holding tank and flush the sprayer.....
lesterj2
SRI Cleaning said:
Les, Are you using carpet cop as your prespray?
yes... i called the manufacturer and they said it would be fine they also told me the mix ratio...
i havent had any complaints or problems as of yet (knock on wood)... works great IMO...
You could reuse it. You might need to add some fresh enzymes, but you could reuse it.
Mr.V
haven't really tried it but I always thought it would make more sense to put peroxide in the rinse myself
used brown out in the chem feed on some pee filled carpet ,,,,,worked wonders
May I suggest that you use sodium p to add to your prespray as an oxy boost,and save the 40 vol for those tougher stains that need a little more umph.
Kevin
lesterj2
Kevin
where could the SODIUM P be purchased...
lesterj2 said:
Kevin
Sodium percabinate
you can buy it most anywhere.
Wal-mart, Home Depot, grocery store
it's know there as Oxy-Clean
Yes, the stuff that Billy Mays hawks
lesterj2
ok i heard of OxyClean but how much should i mix per gallon of prespray...
but if i was to get the big bucket of SodiumPrecarbonate what would the mix ratio be for it...
My guess would be 1/4 oz per gallon....that's what boost all dilution ratio is from bridgepoint. So it should be that or less depending on what additives are in boost all????
XTREME1
Ma
Greg Crowley
I would just dump it. Every morning I mix my first gallon of prespray with boiling water and then I mix each job and always use it up. If I didn't I would dump it
davegillfishing
st augustine fla
dave gill
that is what we do, you will get to the point where you dont have much left over..it just takes time and you will be able to gauge how much you will need. i smile every time my sprayer starts to blow air and i am at the last inch of the last room.
dave
