let this be a lesson
if you install flooring and 1/4rnd or base molding is part of the job and/or do any finish construction on WD jobs
got an e-mail this morning
One of Home Depot's flooring contractors put a finish nail thru a water line in the wall while nailing up new baseboard
here's the kicker, it was installed 3 years ago
Had to be a drip in the wall that leaked to the outside undiscovered :dejection:
….til the nail rusted/corroded enough to pop out and jet spray cut thru the drywall :eekk:
the mess has been cleaned up and pipe fixed .
The homeowner wants us to finish
(we've done $30K in remolding there over the years)
damn thankful it wasn't our FUBAR :eekk:
gun safety rule #4 applies here
"Identify your target and know what's beyond it "
Hack Attack
Dan
Relatively new build 7 months old..
Mold on face fibre of carpet and the smooth edge (U.S. tackless?) the ensuite is behind that wall its a leaker...
My friend had that happen to his house a few years ago. Over time that nail rusted and sprang a leak.
Seen it on radiantbheating pipes.
Took 4 years to show up as they only used the system two months out of the year
Wool in a master closet
The mold stench was unreal, but went ignored
Found a similar situation when helping a friend install new carpet. When removing the old carpet, we found mold and rotted 2x4's at the base of the wall. Turns out he installed track lighting 4 years earlier and on screw slightly nicked the down spout of the upstairs shower drain.
Willy P
Willy P
Was pounding tackless one day, finished the install GOT home and GOT a call about the basement flooding. Turns out it radiant heat and one of the nails pierced the hw tube. Learned that a mop is my best friend when doing radiant floors.
