Like to put some EN-cap juce in with my rinse ,will it work
postaldave
Does anyone make an En-cap that goes into a HWE Rinse?? .Would think it would save me from going back to encap after HWE , and keep the wicking down. Or the Another Step, Taken to lightly spray some down after Hot Water Extraction a Rat Nasty Commercial Carpet. Just haven't been sold on the Idea of Cimexing without Extraction. Postaldave
A
amazingcleansc
End Zone by bridgepoint
Releasit Encap Hydrox
actually, technically couldn't any encap product go on the back if it could handle the tm heat?
sweendogg
Bloomington, IL 61704
David Sweeney
If you plan on running an encap rinse as a stock solution through your truckmount you'll want to use a product designed specifically for it so it so the heat does not compromise the crystalizing properties of the polymers.
Encap punch from Releasit
Quite a few products from Vacawy like their Rinse and Stop and Shatter.
Low foam snake oil from Judson are two
charles
Check out Scots Tuff Ultimax Plus Encapsulating Acid Rinse.
I've been using it for a couple of years now.
Encapsulates and crystallizes residue build-up
Prevents wicking and reduces rapid resoiling
Speeds up drying
Neutrallizes alkaline detergents
Stabilizes dyes
Recommended for high heat equipment
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
Groom Solutions Peroxicap has instructions on the label how to use it in the rinse.
Bridgepoint's new Encapuclean O2 is another great product for use in the rinse.
Ryan
Peroxicap is amazing stuff....
