Little Giant HOT'O'MATIC
AshleyMckendree
Ashley Mckendree
I have the old "Round" Little Giant HOT'O'MATIC... what does it compare to in the newer Little Giants? 3ht? 4ht?
I will be getting the coil repaired w/ silver solder so I can start using it again, my Mercedes Diesel just doesn't put out enough BTU to give me decent water temps :(
well.....do you have a #2 or #3 round?
Same coil.
I would just excersize some caution, the walls of the copper probably aren't what they used to be, keep your pressure down.
AshleyMckendree
Ashley Mckendree
Same coil.
Normally I run 600psi, the highest I go is 700 for T&G.
