Tell us how you like the machine.
I am not familiar with the Thermalwave.
The truck is awesome.
I wanted to get one but I just signed a contract on a new home today.
That means I will not be getting a truck anytime soon.
I am going to check on shipping rates for this tank. I also need to check with a local cleaner that said he wanted it. If my price doesn't work for you, then that is not a problem as I will eventually use it. I think I can get you a good deal on it and get what I want. I'll let you know within the next couple days. If you want to get a bigger tank, that is fine as well.
Someone posted the other day about carrying freshwater. Well some of the homes I clean have the water off and the water is locked at the street. So I need to conserve water which is why we run on low about 50 percent of the time. That is usually not a problem if the carpet is not heavy soiled and I can use a pump sprayer on most of the job. Well the other day my pump sprayer broke for good. I was out of town and had my brother do a job that was 10 areas heavy soiled. He had to use the hf and clean with what was in the tank. I don't know how he got through the job but he did. This is why I would like carry more water, but for you this tank plus what your machine will hold will be sufficient for most jobs. If not you could always add an extra tank.
