Looking for ideas on a fresh water tank
Ross Buettner
Ross Buettner
I need a tank ( the unit I bought has none). Aside of Prochem's tanks, are there any others out there I can look into? Any help would be appreciated!
Ross
I bought this one for mine for a few hundred bucks....I had them put in a few fittings for me....once I got everything figured out I don't even need it....this one is a 150 gallon....the smaller the cheaper they are....also found a flow pump for it...but never put it in..........
CRASH...is using a 55 gal Poly drum with a ballcock plumbed...
the Hydra Cell pump is drawing the water from about six feet away....no Sureflow pump at all...
it's working great........
they make tanks like Jims that stand vertically, very small foot print, at least 150gal capacity. Maybe a couple hundred dollars
Art Kelley
joeynbgky said:
55 gallon drum works good.
Had that in my old Steam Genie. I had to put in a 12v pump to feed the machine. I can remember every time I made a sharp left and 50 gallons of water would dump in my van and pour out under the doors onto the road. Never failed to disappoint me.
joeynbgky
Joey
TCS installed this one when the machine was new.. So it has screw on caps.. Never had any problems with it..
Mytee tank would be a waste of space for a water tank. Its great for a recovery. You don't need that support for a freshwater tank
