daniel@procarpet
- Joined
- Sep 7, 2008
- Messages
- 3,797
I have a Prochem Legend XL. The temperature doesn't seem to be right. In fact, the temperature has been off for a while. What temp should my machine realistically hold at while cleaning carpet with a 6 flow wand at 300 psi? After doing a fairly large job today in 70 degree weather, I checked the temp on the mahcine and it was at 140. When I keyed the wand, the temp jumped up to 230. Within 10 seconds after keying the wand and holding the trigger the temp was back to 140. I feel my machine should hold at least 180 to 200.
I checked the temperature relief valve the other day and it was slightly leaking as soon as the machine was turned on. After replacing it, I thought my problems would be solved. There is a chance the new valve could be defective but I highly doubt it. The heat bypass valve appears to be in good order, but I will do another inspection of it. Again shouldn't my machine hold in a general range? Whats up with the sudden temperature spikes and declines? After prespraying and getting the machine hot, the temperature drops to 140-150 as soon as I clean half a room. This machine should hold at 200 in a warm climate like mine shouldn't it.
