So be sure to READ the whole thing before you answer...cuz i know some one is going to say something like "do you have gas in it??"
So its an everest, and has been running like a champ, only worked Last monday for about 4 hrs, and was just fine.....Had a job Saturday about 30 min into it, it just shuts down....I was thinking hummmm over heat?? no radiator and antifreeze were fine...ok turn the key fuel pump working.....10 min later again....hummmmm....look over it again, everything looks fine, this happened about 3 more times, finally had my dad go grab a new fuel pump..
When he left, i took the outlet house off, and it kind of sputtered out fuel, then smoothed out...OK get it running..... somewhat amus somewhat amus somewhat amus
30 mins later dies :x :x ....ok put on new fuel pump...fixed. :mrgreen: :mrgreen: :mrgreen: ...........................30 mins later, dies again :shock: :shock: :x :x
Call Tim from on the board, he comes over and we play the game a few more times, runs for about 20 mins, then dies, then every 5 min :x :x :x :x :x :x :x :x ......so we use his machine for a bit....
Heres your info...
Unhooked from the carb back at different connecting points, no fuel
even right at the pump.....
took the draw tube off the T (other side is the return back to the tank A 12 gallon marine type tank) Put it straight in the tank...now we have fuel.... :?: :?: :?: :?: :?:
Go back to using my machine, runs fine for the rest of job...2 hrs
So i figure draw tube plugged...nope
T plugged....nope, cleaned both out, wire wheeled them, new teflon, air hosed them out
Bought all new fuel and return line, mounted fuel pump under boxtruck (to make sure its cool and below tank)
Ran it at home for ehhhh 20-30 mins, all is fine...
Tonight, get into it 30mins, SHUTS DOWN AGAIN :!: :!: :!: :!: :!: :!: :!: :!:
took lead off of T right into tank AND IT FREAKING WORKS FOR THE NEXT 4 HRS :!: :!: :!: :!: :!: :!: :!: :!: :!:
WTF is going on???????
filter on pump is new
filter up by carb is like 10-15 hrs old...
Why does it work being put right into the gas, and not by using the draw tube with the return???
Heres your info...
