matrix miracle odor
Luis Gomez said:
Is this product the same than CTI's OSR or is the chemistry better?
From what I've been told.. almost exactly the same but you should hear that from Big Billy Yeadon's post not mine.
juniorc82
stick with the osr . I tried a sample of miracle and it was junk. It had hardly no fizz action at all.
KevinL
Kevin Leach
Does the fizzing action make osr work? I can't wait for either one to dissolve.
When considering this type of product, you should also take a look at PetZONE from Interlink Supply. It is more concentrated than OSR so you are less likely to get white powder residue. PetZONE also adds some hydrocide.
With any of these type of product, the hotter the water, the better the results.
I bought a whole case of Matrix Miracle. I used the whole case over time on several different situations and over time determined that the product isn't worth a nickle.
