Brian R
I found these guys...they are in Walnut Creek...I am sure there are others.
Just thought I would post it.
Mikeyimitators.com
Mikeyimitators.com
Owner Operator Scott Sunkel, a 25 year veteran, is known as an industry leader
Brian Robison said:I found these guys...they are in Walnut Creek...I am sure there are others.
Mikeyimitators.com
The term "Steam" is a misnomer since the temperature to required to generate steam is never achieved (240° F) and would actually delaminate the carpet fibers from the backing. The recommended temperature is 180 ° to 190° F, and most truck mounted equipment manufactures are able to maintain this standard.
Louis said:The term "Steam" is a misnomer since the temperature to required to generate steam is never achieved (240° F) and would actually delaminate the carpet fibers from the backing. The recommended temperature is 180 ° to 190° F, and most truck mounted equipment manufactures are able to maintain this standard.
Last I checked steam is created at 212. I guess this industry leader has never seen a real Tm with serious heat.
