M
Mike Draper
Why dont we put to test the high flow wand concept and see if it lives up to its hype? Here is my idea. Take 3 wands. A TI wand pimped at 12 flow with 1" check valves, a TI wand stock, and a ho wand with 1 single jet that sits up high. We'll take one machine up to full heat and then with a thermal imaging system well pull the pimped ti wand backwards with no vac hooked up, this way well see the immediate temp of the water on the fiber. Next we"ll pull the stock TI wand backwards and finally the Ho wand. What I would like to see is if there is a temperature difference on the fiber due to the larger droplets of water and the jets being closer to the fiber on a high flow with check valves? Would be interesting to see if there is any difference between a pimped ti wand and a stock one. And finally, to see how much more heat is lost when you are using a ho wand where the jet is 4" off the ground.
We could then takes both Ti wands and use 2" hose to extract water, then 2.5" hose to extract and see if there is a noticeable difference in the thermal imaging?
