mixed RTU pre-spray shelf life???
I figure most common pre-sprays are stable for days/weeks after mixing.
I know oxy boosters loose effectiveness.
What other mixed RTU chems loose efficacy over a period of days/weeks?
..l.T.A.
Rex Tyus
Enzymes. Some are temperature sensitive as well and the shelve life could be as short as some oxidizers. Check with the manufacturers to be sure.
Jim Nazarian
So. Cal
Jim Nazarian
I love using Enzymes but there only good for a day.
MasterBlends Soapfree is another favorite, but it needs a couple of scoops added after a day or so of not being used up.
Rex Tyus
It depends on the enzyme and the temperature sensitivity. I spoke with one of the chemist at CTI once concerning Prozyme and they said as long as it is mixed with cool water it will last a "week or two".
Arizona
I mix 20 gallons at a time and carry my RTU....
I already knew the 02 would be fine for a real long time
I called Steam Pros on there first step and the active 100 and there's has a very long shelf life
and I called Steam way on there maxpack TLC and it has a very long shelf live
