tman7
Is there a way to get more heat out of a Hydramaster CDS without a blower exchanger? Right now I get pretty consistant heat of 190 from three heat exchangers. The way its configured now, it takes the coolant directly from the block (what would normaly go first to the heater core) and then to my Xchangers. Would I get better heat if I took the coollant from directly before (or after?) the engine thermostat and then to the exchanger? Or could this casue issues to the van engine with such a choke down of coolant hose size feeding the radiater? How about air in a system like this, IOW is it nessesary to bleed air?
Thanks for your input
