More Giveaways at Cobb Booth #633
Mytee has donated a box of these HeatGuards for the Experience exhibition:
http://www.mytee.com/products/a104-heatguard-vacuum-and-solution-hose-wraps/#.UgxlCRasalI
Looks like they would good on lead hoses or upholstery tools.
John L. requires some juicy gossip about Mikey to qualify.
Come by and tell us your story.
Booth #633 is a corner booth to the right,
when you're facing the Budweiser serving area.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
John L should worry more about electrocuting his customers, peeling chrome plating, cracked joints, rusting hardware, carbon fiber splinters, soaked baseboards and shredded seams..
You want to bet that even those pot holders will fail?
I think it is great idea, I even spoke with him about the idea a while back.
Mikey;
We have a 230 VAC TRex hooked up for you . . .
in the submersion rug cleaning demo area.
The electrolyte in the solution will make you taller :angry:
Reactions: ruff
maybe some copies of Dale Carnegie's How to Blow Smoke Up Peoples Asses would have made a more useful gift than those stupid pot holders.
Mikey;
bring that turd over to the Aerotech, we'll hook it up to fifty feet of 2.5 and blow the gear box back to Taipei
Seriously, no insult intended, why would a Mytee owner need a heat guard?
Because if you can fool yourself into believing a portable is professional, you can fool yourself into believing tap water is hot too.
:lol:
They are for when using the trex, to bundle all cords and hoses together and move them as one instead of three. Will try it tommorow and see.
So, let me get this straight, this "heat shield" is really a hose bundler? Now that's sort of like OP extraction!
Or a "Electric Truckmount" that needs the van to be running for it to work. .
It should be a heat shield that bundles the hoses and cords. Again if it lasts it should be a winner for all rotary extraction unit users.
Are there threading, seams, fabric, chrome plating, glue, hose clamps, wire nuts or any thing else that can possibly go wrong?
If so...
That is a problem when we use our Powerglides, you can wrap up the power cord or the solution line in the head if you don't keep them away as you clean. Those should work well if put on the lead 10-15 feet.
Yes just for the part of the hose, finally Chavez gets something!
Is "not so Crazy Ray" part of what Larry gives away?
Hey I maybe sloww but give me time and I'll ketchup............and even mustard. :very_drunk:
