Moving a shaft drive WM
My next project will be moving a faithful White Magic Pro 2000 from an extended 1999 Chevy 3500 into a 2012 Chevy 2500.
Should be pretty straight forward putting it all back together, restoring as I go. The glitch will be going from the 5.7 engine to the 4.8 in the newer one. Also going from vacuum pod speed control to electronic.
I'll take some pictures as I go, even of my goof ups.
The last time the '99 needed to work was last November just before our AZ trip. We've managed at reduced capacity since then with the 2014 Chevy/ prochem 405 setup. However I missed the ease of the direct drive setup, and occasionally NEED two trucks here. Justin lets me borrow one of his, but it gets crunchy juggling routes.
Somebody said it couldn't be done, so that made the project irresistible to me. Suggestions and such appreciated. I'll try to remember how to post pictures again.
Thanks!
I should have bought Fred's back in 2009 or so when he was parting it out. Still running his Cat pump.
Reactions: FB19087
I loved that thing.....only thing I have left off of it is the roots 47 I swapped in for one of the 4MPs
gave the tanks and frame to the local meth head metal guy
Thanks!
Nice project. Keep a record of how many hours you put in. Hopefully you can use the same driveshaft. I always hear it's too expensive to move a pto.
Rick J
rick Jones
I have heard that as well.
A large outfit here did it on a regular basis. Had the distributor do it. While WM was still viable.
don't know now though.
They, the distributor, told me that WM parts were hard to come by nowadays.
Thanks!
I will be following this. I really miss mine. It was easier to work out of than the butler.
Steve Lawrence
I'd like to move my 96 Butler to a new truck. It's still just a baby with 8000 hours. Anybody do this? I've also got a 2010 with about 10,000 hours we should probably move to a new truck soon, or sell the whole thing. Truck engine is getting a little tired, maybe.
Do not know it true but heard that some sort of tom foolery with company monies was the culprit.
yep...at least that seems to be the cause
went out of biz in December 2010....may be other factors
wish you guys well
but this is the main reason I never considered a DD.
(in spite of the their virtues over slde-ins)
The unit WAY outlasts the van
and if you can't afford or don't want $1000-$1200 hundred plus a month payments ...forever
In 7 to 10 years, the van's worn out, beat to hell and/or looks like it belongs in the demo derby
but the unit barely reached it's half life for the Carpet Commando that averages 500-700 hours a year
(and less than that now that Oh-Pee is gonna be a thang)
and you can't just fork it out of one van, and bolt it down another on a Sunday afternoon
Doug Cox
Doug Cox
I swapped a Hydramaster CDS from an older chevy to a newer model years ago. Don't remember it being too difficult, just takes time. Yep, my machine was 25 years old when I sold it and last I heard, it was still running.
The first owner of mine got ten years out of it, until the end of his career.
The boys put a new crate motor in it in 2011 and it got nearly another decade.
It is great to work out of, I have an electric reel at the side door, everything easy to reach. 2 x 100gallon waste tanks, 125 fresh. Two 45 blowers, 5cp pump, no transfer plumbing needed. There are advantages to both....so I will have both.
I just paid out my lease on my2016...
I’m embarrassed to say what the rig finally cost me...
88,600.....
But, it’s made me 980,000 over 4 years....
You should be embarrassed if you spent that much on cars and boats (Damon Fever) just to play in. But for business sake...$88,600 is pocket change compared to other businesses. If it made you money over 10 times the amount you spent...you shouldn't be embarrassed
You couldn’t keep up with me even if you had a tailwind.
Rob Grady
Rob Grady
Will you be running 'v' belts or serpentine on front end? I wonder if the new van on drive by wire would require the 'high idle ' feature?
Do you have the mounting brackets for the 4.8?
6 rib serpentine. (Would prefer 8)
I'll drop 300 on an electronic speed control. (I want adjustable/ multiple speeds)
I may have to fabricate a front end bracket.
Hope it's not a 120 inch serpentine
Running a Gates HD green stripe
It fails once it's stretched an inch
The stock crank and pulley stays intact, a second machined pulley is bolted on the front of it.
Is the crankshaft pulley compatible on the 4.8 from the5.7?
To answer the spirit of your question, there are other potential issues. Perhaps bolt locations for the belt tensioner and the clutch (front end attachments).
The shaft has to be on the same angle as the engine crank, and fit in a precise area often in conflict with AC compressor or other components. That will be issue #1, that will dictate how to proceed.
