daniel@procarpet
My EVEREST is plumbed to bypass hot water to the waste tank.
I read you plumbed yours to go back to the freshwater tank.
My machine runs HOT. If we run the machine on medium single wanding the water runs too hot so it dumps a little. I go through water quick. If we dual wand we do not have any problems as long as we are cleaning non stop. If we stop to move things, the water temp jumps up quick.
If we plumbed the water to bypass back to the freshwater tank, we would conserve water.
Will this hurt the pump in hot weather?
If the water gets low and water is bypassing back to the tank will this overheat the water?
Just curious.
I am not likely to go against the original design. I just wanted your input.
Just curious.
