Nov 5, 2007 #1 V vincent Member Joined Oct 6, 2006 Messages 1,899 Location O'Fallon, MO Name Vincent Sapp I need a replacement suction hose that goes inside of the jug. Where can I get one?
Nov 5, 2007 #2 Dolly Llama Number 5 Joined Oct 7, 2006 Messages 30,785 Location North East Ohio Name Larry Capitoni Home depot..er...ah...Lowes or most well stocked hardware stores. Farm supply store should have some too It's just 1/4" ID vinyl hose, isn't it?? ..L.T.A.
Nov 5, 2007 #3 V vincent Member Joined Oct 6, 2006 Messages 1,899 Location O'Fallon, MO Name Vincent Sapp Ok makes sense, but do you really need the filter at the end?
Nov 5, 2007 #4 V vincent Member Joined Oct 6, 2006 Messages 1,899 Location O'Fallon, MO Name Vincent Sapp How about a zip tie and cheese cloth, that should work, right?
Nov 5, 2007 #5 Dolly Llama Number 5 Joined Oct 7, 2006 Messages 30,785 Location North East Ohio Name Larry Capitoni If you're concerned about the filter, then buy a brass hose barb w/threaded female end. i don't think i've had a filter on mine for over two years. I use an 06 or 08(?) flow jet on mine, so any crud generally gets spit right thru ..L.T.A.
Nov 6, 2007 #6 Johnny Supportive Member Joined Oct 22, 2006 Messages 2,367 Location La-Z-Boy Name Johnny I also run the MS filterless. No prob.
Nov 6, 2007 #7 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Location Dallas, Texas USA Name Larry Cobb Vincent; It is better to use a chemical-resistant hose in your sprayer. It won't harden like vinyl hose. I would use the barb and large filter to prevent jet restriction. Larry Cobb
