multi spray parts
vincent
Vincent Sapp
I need a replacement suction hose that goes inside of the jug. Where can I get one?
Home depot..er...ah...Lowes or most well stocked hardware stores.
Farm supply store should have some too
It's just 1/4" ID vinyl hose, isn't it??
vincent
Vincent Sapp
Ok makes sense, but do you really need the filter at the end?
vincent
Vincent Sapp
How about a zip tie and cheese cloth, that should work, right?
If you're concerned about the filter, then buy a brass hose barb w/threaded female end.
i don't think i've had a filter on mine for over two years.
I use an 06 or 08(?) flow jet on mine, so any crud generally gets spit right thru
Johnny
Johnny
I also run the MS filterless. No prob.
Vincent;
It is better to use a chemical-resistant hose in your sprayer.
It won't harden like vinyl hose.
I would use the barb and large filter to prevent jet restriction.
