multi-sprayer
bought a used one great shape tc model is this how you charge it just by leaving it pluged in to the cig lighter for how long ? isnt there a nother way of charging it ??
E
Ernie G
Yeah Scott, thats the problem with those sprayers imo, it would be nice if there was the option to plug it into the wall also. I have two of them, they are expensive, they have some good features, but I think they could be improved.
do you leave it in the cig lighter all the time when your not using it. could you possibly over charge it? could i use a inverter to charge it?
charles
I leave mine pluged in all the time also, I've had the sprayer for 4-5 years and only replaced the battery 1 time. I have 8 of the 2gal containers, I have 6 filled with pre-spray and 2 with teflon.
X
XTREME1
I have a battery jumper pack that I keep charged in the shiop and [plug into that
charles
I don't think it pulls enough to drain tha van battery, I've left mine pluged in for 2@3 days without any problems.
Loren Egland
Loren Egland
I have had mine for over 7 years and have never replaced the battery. I keep mine pluged in all the time, but I just use a couple wires to my truck mount battery instead of using the cig lighter.
campusman57 said:
it wont drain the battery on the van ?
no, cause the multi-sprayer isn't on (running) when on the charger.
You could leave it plugged in for a week and it won't drain your battery
Leave it plugged in all-de-time when not out of the van being used.
(yes, between jobs too)
Your battery will last longer
