Muthers day cleaning
Bjorn
cleaning on a Sunday morning
techno-viking truck mount
a friend gave me a gallon of some vac-away dirt assassin tried it and it would not even budge this mess so back to the truck mixed up some judson 02 pre spray and o2 rinse and melted it away like magic
with 220 degree heat helped a little too
Bjorn
sorry sunday morning in down town Lynden wa had to go electric
Bjorn
I ain't going to wand something like this a good pre-scrub Rx the SOB
heck Ron I didn't even pre-vacuum
yes miss clear-track the tables were moved
Art Kelley
Clawson,mi
Outstanding work Terry. Nasty gross carpet. They have to stop that grease from tracking back in.
Bjorn
No hot sauce was used I was very disappointed with the Vacaway dirt assassin
Brian R
Little Elm, TX
Brian Robison
Try Intensity Red Teri.
Best thing for the grease....Top shelf...that should mean something to you I'm sure.
Bjorn
Try Intensity red?
how could anything get this carpet cleaner with ease than Judson juice does
the top left I tried the vacaway product it did not budge the grime
only thing I did was mix 3 ounces per gallon of O2 pre- spray and 1 1/2 gallon per hour on the meter
just around 220 at the RX the flow is 10
just cant see how another product could do any better unless your seeing something I don't here
Brian R
Little Elm, TX
Brian Robison
Odin said:
Try Intensity red?
I'm sure Judsons is fine. I was just suggesting another product from Vacaway because you mentioned the name.
I'm sure there are other things that will cut the grease as well.
When I use IRed, I haven't had a problem with any greasy nasty situations.
Although I will admit I haven't tried to clean a carpet like that one in your post ...you don't eat there do you? Yikes.
If you do try it on a restaurant like that, I would love to see or hear the results.
Intensity Red I believe is the most powerful cleaner that Vacaway has for carpet. I could be wrong.
Goomer
Bronx, New York
Frank Mendo
Odin said:
how could anything get this carpet cleaner with ease than Judson juice do..............
just cant see how another product could do any better.....
JJ is good stuff, but come on now, that's being silly.
The RX sure makes it easier, I've just never needed mine.
The O2 works great but at 3oz/gal, gets too expensive to use. I use ATTACK from Cleanco, 12-16oz in an Master Clean spray jug, sprayed out at 4:1. So I might be spraying at around the same mix but I need the O2 more for residential.
joe harper
florida
joe harper
Re: Mothers day cleaning
You guy's FrEEkIn KilL Me..... :roll:
3 ounces of ...."02 juice" .... cost a 'WHOPPING"... (.90 cents")... :shock:
You guys are Soooooooooooooooooooo freaking cheep... :oops:
Fuel & Chemical cost are a NON-FACTOR...in our BIZ.. :roll:
Sorry Ron,
BUT the cost that MUST be controlled...is LABOR.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It would cost me ...$100.00 in labor to vacuum a hallway.....at you PACE.. :mrgreen:
Brian R
Little Elm, TX
Brian Robison
Yeah, time is money...Better chems help with that so the price of them is a non-issue....so far anyway. lol
Costs me about $70 to get a bottle of O2 up here. That's 280 a case. Thats even with your sluggish dollar being worth less than ours. My best profit is in residential and its also where they are more concerned about a safe cleaner. Not being cheap, just practical.
I can get a 50lb'r of Attack for 250.
