gimmeagig
- Joined
- Mar 25, 2007
- Messages
- 744
- Name
- Roxy
Hi,
Recently I was lubing my 1999 CDS machine and i found a lot of play in the U joints.
It was a holiday weekend and LPM was closed . So I had a local mechanic replace them. The machine ran fine after that.I ended up doing a bunch of jobs after the repair was done.
Today I went to LPM in Spokane to have something unrelated fixed and I had the mechanic there check the U joints out and he told me that there was play because a clip was missing on the U joint and that that was an easy fix. I had them do it and we tested it and my CDS ran great after that.
So I went to my next job. At first it had a little trouble coming up to speed but then it ran like it should. After about an hour I was going to make an adjustment on the machine and I heard it squeaking really bad ( I was doing an apartment on the 3rd floor so i couldn't hear it while I was working) and before I was able to shut my CDS down it completely died on me.
The driveshaft to the machine can normally be rotated but now it is completely frozen and I have a bunch of jobs coming up. LPM was already closed when it happened but fortunately i have no jobs tomorrow and I'll be able to take the truck back to the shop. Then I'll find out what is going on.
But in the meantime I'm still freaking out a bit, wondering how bad the damage might be. I really don't need a 1000.- repair bill right now.
From what i just described, do you guys have any idea what i might be facing here? Is it the clutch, or can it just be a frozen U joint? Or a broken drive shaft? Or something else even worse?
