Brad it worked well but would only maintain about 200 atm with two lines. I feel some exhasut still escaping through the pipe instead of it all coming through the heat exchanger. Also I was peranoid about back pressure when i had my welder make my heat exchanger that i think it is flowing to easily through the exchanger, in other words i think i need to make it a bit more restrictive to achive greater heat. When i was single wanding it was at about 235 atw( checked with a uei digital therm) but right when my helper went back to work it dropped significantly. I used aproxitmately 350 gallans of water that day of wich i approx recovered 300. The truck ran fine all day and was very impressed with a three hundred foot run to the furthest point i needed to clean. Still taking me a while to work with the
glide. it feels to easy compared with what i am accustomed to using that i stop every twenty minutes to check what i have done to make sure it looks good. This job had paint overspray and drops everywhere, they thought they were going to replace the carpet so they didnt use any drop cloths or plastic. It alos had alot of carpet adhesive just about everywhere but I got about 97% of everything out and everyone was impressed to how it looked in the end. I was very carefull with this job because all i did was about 10,000 sqft, but the whole church is about 415,000 sqft so hopefully i can get the rest of the account and have work for the rest of the year!
