my v was offline a while.
THANKS TO JIM MARTIN FOR THE ASSISTANCE IN LOCATING ISSUE! 8)
after a couple of hours of investigating the fix only took twenty minutes. it ends up that the pto solenoids inline filter/strainer was clogged with debris from the current tranny rebuild ( i am guessing). i didnt know it but in all of the stuff i got with my two v s i had one of these in a box. the install took about twenty minutes and now the v is back up and running.
here are some pics.
i think it was the filter or inline screen was clogged but i ended up replaceing the whole thing.
this is the solenoid i installed.
this is the used inline filters/strainer.
this is the new inlne filter strainer.
filter side on new strainer
complete pto solenoid assemlby ready to install.
this what the original looked like and it was a peterpaul electromincs 06050 solenoid.
dgargan
Thanks for the call and pics Micheal, I will check mine out later.
Brad on Dave's puter
M
minuteman
You can find those on a Diesel fired pressure washers. They are wired to the pump switch, pull the trigger
on your gun-pump blasts the water-triggers the switch in pump head-flips that switch & allows the fuel to flow to the burner to fire for heat. Electric magnetic flow switch.
Greg
