mytee 1003
K
KOOSER55
ive gotten offered a machine that hasnt been used to much that is about 10 years old for around 1200 but a new one is only 2200 has anything changed on them with in the last 10 years i would of thought so but im not sure
rotovacguy
$1200 for a 10 year old porty? That's crazy
Yes they have changed, those old ones were built with 100psi pumps, and the vac motors were in air-series (one sucking behind the other), so there was only a single 1.5" stack pipe in the waste tank, and there is a good chance teh one you are referring to used 2 stage vac motors, I would call it a 100cfm machine. You can bet the heater is caked with detergent and scale, if it's even still installed.
Todays machine would be a 200cfm, dual stack, and have a 450psi pump, and heat.
For $1200 you could probably get a current brand new 100cfm/100psi machine, look at the Breeze or RL100 on www.mytee.com
