John LaBarbera
1005 DX will work for food. Needs a good home.
Send money to Mikey. Auction end Friday 3/5/10 pacific standard time. This machine is pretty much the same as an M5 with out the auto fill and pump out. Same vac motors and high flow, 500 psi pump.
Item - Speedster 1005DX.
Starting Bid - $1,300.00 - Includes freight in the Continental U.S. (NOT Hawaii or Alaska.) or Kenya!
* M.S.R.P: $2,009.00 (Plus S/H)
* Warranty: Limited lifetime warranty
* Body: Roto-molded polyethylene
* Tank: 12 gallon
* Vacuum: 2-3 St HP
* CFM: 230
* H20: 148"
* Pump: Piston
* PSI: 0-500
* GPM: 1.45
* Heater: Optional Heating Solutions
* Wheels: 12"
* Casters: 5"
* Cords: Dual 50' 12/3
* Dimensions: 20" x 30" x 48"
* Weight: 135 lbs
Link for more info:
http://mytee.com/products/product.php?id=1005DX
* Tank: 12 gallon
* Vacuum: 2-3 St HP
* CFM: 230
* H20: 148"
* Pump: Piston
* PSI: 0-500
* GPM: 1.45
* Wheels: 12"
* Casters: 5"
* Weight: 135 lbs
Link for more info:
