Mytee
Zee
I got one of the inline filters 2.5". I think its about a year old.
As of today I got tired of the junk collapsing on every job. I run high flow high heat and the filter collapses onto the mesh inside- I'm assuming losing a lot of airflow in the processs....
I know this has been brought up before. But don't feel like searching right now. Was there a way to replace them with a newer version without buying again?
Or who has a better filter 2.5" The twist on hydrofocre? Is it better?
I have the twist on hydrofilter. Its ok but the screej is falling apart again.
The Devistator filter (sp?) looks good and sturdy. Big and pricey too
vincent
Vincent Sapp
I have the clearview Joe Bristor sells. Was running 4 to the door, but switched over to straight 2.5.
Excellent filter for the money.
rwcarpet
Robert Hodge
Again I say........a good pair of "waist high panty hose" in the tank filter basket collects all the junk. Pull it out, toss it, and pull on a new one. Helps keep the tank a lot cleaner.
John LaBarbera
You're in SD County. Just bring it in to us at Mytee and we will replace it at no charge. See Chris in customer service.
13655 Stowe Drive, Poway 92064
John LaBarbera
Zee
Thanks for the offer John! Prochem are you watching??? Hahhahha. Willy just teasing you...
So John did you change the material to be stronger?
Willy P
Willy P
John gets "it" and gives great customer service. My problem is I hold others I deal with to the same standard of service as I give. For the most part, my supply chain delivers.
John LaBarbera
Yes, redesigned from original and 33% more poly.
John LaBarbera
Marty said:
I am willing to pay more if it's worth it. The Devastator is worth it.
Wow, I've heard everything now! Just playing with you Marty. I was just surprised.
How much more would you like to pay? Is the length a consideration? Can the filter be longer?
Leggs knee highs sucked into the vac ports and secured with rubba bans.
Hear. Hear.
And better vacuum.
John:
I am not quite sure what filter you are asking about. If it is your filter, I have no idea. I have never seen one. The Devastator filter is big, but not too big and it is the most durable and efficient filter I have ever seen.
John LaBarbera
John:
I am not quite sure what filter you are asking about. If it is your filter, I have no idea. I have never seen one. The Devastator filter is big, but not too big and it is the most durable and efficient filter I have ever seen.[/quot
Hi Marty
What are the dimensions of one the is big but not too big?
Thanks
John LaBarbera
John:
Hi Marty
What are the dimension of one that isnot too big?
Thanks
