MYTEE'S NEW PORTY
John LaBarbera
MYTEE'S NEW PORTY
Giorgio
Giorgio
maybe it's powerful enough to leave the machine downstairs and only run the hoses upstairs.
wouldn't that be a kick to the head!
Bob Foster
The Speedster LTD looks great in person.
The Presidential Club is a select and limited group of Mytee distributors that have met a higher requirement of Mytee's for how these distributors handle Mytee products and Mytee customers.
with 2 3stage vacs, you can leave it down stairs, or upstairs
Just hope you don't get a call to the 3rd floor of an old building with no elevator
jstucky said:
weight??????
It is listed at 135 lbs (20# less than the M5+) .
according to the Mytee new catalog from Connections.
It also has less vac loss in the plumbing.
President's Club Member
John LaBarbera
juniorc82 said:
so its really just an m5 with a high pressure pump is all
I can see why someone would conclude that. However, if you take a closer look (in person, rather than just a picture) you'll see quite a few difference from other machines in the market place.
Mytee has incorporated many features that PCC's have requested and, for the most part, are now wrapped up in the Speedster LTD. There is one model at this time but there will be 3 shortly.
Besides the 1000 psi pump that allows for tile or carpet cleaning the following list will highlight other changes.
1) Solution tank drain
2) electronic vac motor shut-off
3) Motor compartment is larger and the vacuums are connected with-out hoses for the most proformance and minimal CFM drop. It is very easy to service
4) On-board chemical injection
5) Pnuematic wheels
6) repositioned switches and psi gauge
7) on-board defoam injection
8) Transport tray that allows the operator to make one trip with the machine, 2 gallons of chems, wand, 50' of 2" hoses, upho;stery tool and other acessories.
9) Audible circuit locator tone that will sound for 5 seconds when dual circuits are found.
10) A new ventilation system
11) an easy attach muffer system
While this machine is not for everyone, for those who need it, I think they will like it very much.
mwall2230
Mike Wallace
John, looks like you did a good job. It's nice when a manufacturer actually listens to it's customers.
