natural stone cleaning vs. stone polishing
  • Thread starter prestige cleaner
  • Start date
P
prestige cleaner
is there a difference in these two methods both are achieving the same result?
The polishing process will have you cleaning the floor first.
Cleaning and sealing only will not give a polish to the dull or scratched floor and in many cases by removing the built up layer of skin oils, dog hair oil and mop water residues will cause a dulling effect in the clients point of view. When in reality you are just restoring it to like new.
You may need to open a closet or lift a rug or piece of furniture to prove this point.
Josh;
The cleaning process insures that there is no "grit" on the stone that might scratch it.
Then you can use the new diamond-coated pads to polish the flat surface.
It will take several steps to achieve the final polish.
We have some photos on our web page:
http://www.cobbcarpet.com/stone.html
