Product ID: 3375-0017-6 Category: Accumulators
HYPRO PULSATION DAMPENER 1/2FPT'
Product Name: 3375-0017-6 HYPRO PULSATION DAMPENER 1/2FPT'
Hypro pulsation Dampener
1/2"-10.0 cubic inches
Extends system life
Precharged with dry nitrogen at 600 psi
Max 140°F
Ductile iron body epoxy coated inside and out for corrosion resistance
High pressure brass check valve
Rebuildable and rechargable
I bought a windtrax accumulator once and I think they are suited to higher pressures not the 450-600 psi most of us run. the truck mount accumulators I have seen are all charged to 250 psi, the windtrax units are much higher. I tried letting some air out of mine and it never worked quite right. getting the correct one from john at superior fixed my issues.
mine came precharged so what I did was watch my unit while it was running and kept letting air out till the pulsation smoothed out. it never worked right, just bit the bullet and had john sell me the correct one.
