NEED A pulse dampener OR accumulator
Bjorn
need it for a cat 290 pump if you have one laying around pm me or call
thank you
Ross Buettner
Ross Buettner
Recharge it with nitrogen??
Unless you freez em they either work or they don't. But you CAN recharge them.
WINDTRAX
Product ID: 3375-0017-6 Category: Accumulators
HYPRO PULSATION DAMPENER 1/2FPT'
Product Name: 3375-0017-6 HYPRO PULSATION DAMPENER 1/2FPT'
Hypro pulsation Dampener
1/2"-10.0 cubic inches
Extends system life
Precharged with dry nitrogen at 600 psi
Max 140°F
Ductile iron body epoxy coated inside and out for corrosion resistance
High pressure brass check valve
Rebuildable and rechargable
Price: $109.32
Check Volume Discounts
steve g
steve garrett
I bought a windtrax accumulator once and I think they are suited to higher pressures not the 450-600 psi most of us run. the truck mount accumulators I have seen are all charged to 250 psi, the windtrax units are much higher. I tried letting some air out of mine and it never worked quite right. getting the correct one from john at superior fixed my issues.
Steve you're suppose to charge them to half the operating pressure when you charge them.
If you charged it full then that could have been the problem. ??
You can rebuild them but make sure that you clean all the corrosion out of them before you put a new bladder in them or it will puncture and leak.
It's Terry..............he has the money but hates to part with it!
Especially when he has high end cigars and booze he would rather buy. :p
KevinD
Kevin Dumas
If it is an your traded in cat no need for one if it is plumbed right.
steve g
steve garrett
mine came precharged so what I did was watch my unit while it was running and kept letting air out till the pulsation smoothed out. it never worked right, just bit the bullet and had john sell me the correct one.
