Hi all, I just finished putting my
Vortex 777 back together. I would like to thank Ron Beatty, Jim Martin and Michael Lockhart. Ron for his time and telling me about Michael and Jim. Mike and Jim you guys really know your
Vortex I know I pestered you guys to death but I was desperate. Thank you very much all of you. Ok to what I fixed lol. As you guys remember I was getting a weird noise from my truck. It was narrowed down to either the PTO the pillow block bearings or the blower bearings. I know it could have been several other things but the noise was heard best by those components so that’s where I concentrated my efforts. I loosened the belts on the lower pulley and turned the drive shaft and the noise was felt in the PTO. I was able to move the PTO shaft up and down and after I removed the pto drive shaft I was able to turn the pto and hear the noise. I replaced the rear pto bearing and started the truck. Guys I never heard it sound so quite, it is like a new truck. That bearing was bad from the day I got it a year ago. The pto bearing part number is 550010 Ball Bearing (Output Shaft) the numbers on the actual bearing are 6207 Z.H.B. FAG. Get new seals and gaskets too. Mine is a Parker Hannifin Corporation Chelsea pto model 270 series pto.
http://www.randysdriveshaft.com/pdf/270parts.pdf . I also replaced my u-joints the part number for those where Duralast 1-0278DL. I hope this helps someone else that runs into the same problem. I know how frustrating it is to fix your truck when you can’t find the parts or help. This is a great place to find help with your carpet cleaning truck I am glad I found it, Thanks again guys for your help.
