NEED HELP I need a clutch for my cds 2015
Mr Brightside
Jay Wags
do you guys know what part is interchangeable or any tips my clutch wont engage
Mr Brightside
Jay Wags
Rob Grady
Rob Grady
They don't last forever. I replaced my unit's clutch with one from a Western Star heavy duty truck. I was sticker shocked at the pricing I got from a distributor in Canada at over $600.00.
After a little leg work with the local Auto shops who weren't able to cross reference the part #''s , I sourced one for a little over $200.00cdn. Bolted right in and runs like a champ.
Dwain Ray
This is pitts clutch catalog they make the strongest clutches but napa has the easiest ones to find
Dwain Ray
thats what i was looking for so you have used this for your cds before
I didn't buy that one off Amazon because when i bought the install kit for frankinstien it came with a clutch. But i saved that one in my Amazon lists with the intention of buying it, i thought i had a box with a part#on it for the one's that i have bought from napa but i didn't have it ill look thru my records at home i have the napa part# somewhere, i put it wher i wouldn't loose it according to the people that made the clutch, that label has nothing to do with the model# it a code to let them know who when and where it was manufactured, i researched it out and contacted them several years ago about that,at the time i too thought it was a model# and couldn't for the life of me cross reference it. Ill let you know the part# tonight
Dwain Ray
I knew i wrote that f$%@# number down somewhere, here it is its a carquest#. This is the clutch part# ive used for years, although im going to buy the Amazon one the next time i need one
Mr Brightside
Jay Wags
thanks so much luckily i was able to repair mine and get back on the road still ordering to have on hand also
Dwain Ray
That'll do it, keep those #s cause sooner or later you will need a clutch, and you won't have any problems gittin one glad it was an easy fix
Reactions: Nate The Great
Dwain Ray
If i may make a suggestion, replace your Serpentine belt with a gates fleet runner heavy duty green belt they're more expensive but they're a shit load stronger ,transfer more power and last alot longer they're the only belts i use
Mr Brightside
Jay Wags
Thank you so much for all your help and advice
davep105
Dave Pires
I run a 2010 CDS. Will this clutch work for that unit also? I don't need it yet but wanted to save the part #.
Dwain Ray
Im a steam geni guy so to say yes yes for sure would really be a guess but from all the hydramaster's ive seen i would say it's probably the right one ,i know it fits this guy's i know it fits butlers,steamgenis and Cleanco's, their's not alot of choices for a clutch for this application, if the shaft configuration is correct, clutch diameter is correct and your clutch uses a 6 grove Serpentine belt, i would say yes,yes, for sure,
Dwain Ray
P.S.when you change your clutch change your belt too, i only recommend gates fleet runner green belts . It'll cost you twice as much as a regular belt but is 10× BETTER, the belt is your tools engine and your only as good as your tool
