alazo1
I'm trying to remove the middle pulley of this planetary machine. It is the one in the middle.
I called the company (onfloor) which basically said to use a gear puller. I've tried to heat with torch and use wd40 before using the gear puller. It's really 3 pulleys seperated by some thick washers. The gear puller has bent the washers but I still need to get this thing out.
Any ideas?....thanks
View attachment 1852View attachment 1853View attachment 1854View attachment 1855
