okccarpetman said:
wow fill will slow huh!!!!!!!!!!!
oh yeah does the filter get filled half way up ?
kind of hard to do it it's side mounted, cause it will pour right out before you get screwed on
pour a a qt and half in the fill tube
start it up and run a minute to fill the filter.
shut down, give it minute to settle, then check and top off as needed
Penzoil isn't my favorite brand, but it will do if that's what you have on hand.
personally, i think Valvoline is the best.
But if you change regular and often, it really doesn't matter that much what oil you use.
(as long as it's a commonly sold 10-40wt motor oil)
..l.T.A.
