- Joined
- May 19, 2007
- Messages
- 4,055
Ok, I've determined my flojet pump is kaput. Did a job today and had no water, checked fresh tank and it was full. I have power to the pump. So I took the pump out to check the switch. Switch works just dandy, has continuity and no continuity when pressed in. I hooked the pump directly to a battery and it worked for a second then wont anymore. The motor has no continuity. I also noticed fluctuations when cleaning yesterday so I'm pretty sure it's the motor.
So that's the testing I went through.
Anyways. I'm looking at dultmier and have found some for around 90 bucks or so. It's a 45 psi 4.5 gpm pump model FJ4300-504 http://www.dultmeier.com/products/search/7491
This is the pump
I think it will work but want to check with someone who probably knows.
I also need a new pump for my omni sprayer and want to convert it to a demand pump if possible. Any suggestions for a replacement pump for the omni also?
This is the pump
