Need some advice with boat cleaning
knoxclean
David Gargan
This is something I would not do in most cases but a friend asked if we would try cleaning this job in his boat. The cover leaked and it has some mold. Is this worth trying to save? If so what would you do?
View attachment 4746 View attachment 4747
GCCLee
That's a Sail Boat : )
"Edited above, I need dilutions for Mopping it down"
I've had pretty good success on similar boat situations.
Upholstery tool, lots of white towels.
Is that mold or dirt from water run off? If it's mold, its probably stained and might not be worth the effort.
If its just dirty and rust water that traveled down and left a spot then the likelihood of removal is far better.
The other thing to consider is odor. If it is mold and it has a firm grip on those materials you'll not be very successful in getting rid of the odor. Being a boat and exposed to high humidity mold spores and off gassing from the digestion is going to give you problems with odor.
I would think they would use materials that would do well in high humidity situations so hopefully its not really mold.
As far as cleaning high ph precondition, prespray and allow for extra dwell time and extract with Sapphire tool. Let it dry and inspect results.
Clean it as you would that type of fabric. Spray it with an anti-fungal if you want and clean it again. Don't guarantee removal of the discoloration.
shadygrady
I cleaned a 35foot SeaRay yesterday.I clean boats every year, and yiou would think by now I would know enough to charge more. Water-damaged including woodwork. I cleaned wall panels and the bunk-beds in the side cabin. Mold mostly on outside walls, ceiling in good shape with no leakage evidence. Very detailed working environment, using SS and three individual PMF upholstery tools,switching back-and-forth as needed. I left the ceiling for another trip, as there was no forward berth mattress to utilize. Started out at 8am and finished at 3pm, all for $400.00. Truck ran from 7-3:30, so with fuel costs included, I was doing the client a favour as such. My next scheduled, is a 390 SeaRay, and I will be quoting it at twice the price.
X
XTREME1
I always use a mold remover and bleach and scrub the edges. Be CAREFUL with heat. The glue behind the ceiling gets stiff and with too much heat WILL come down in spots. Get a nylon brush mix cleaner and bleach, gloves scrub the areas that have mold issues. A little purple power around the edging prespray whole thing and go at with upholstery too. Pull all the cushions out first and put on the deck and clean out there. Make sure you lay towels over the sides of the boat so you leave no marks
X
XTREME1
a boat that size with set up and breakdown an hour to an hour and a half. There isn't a whole lot to clean. Your back will hurt depending on your height
shadygrady
So, you are saying an hour and a half for a 35 foot boat using your procedure, highly unlikely that I could ever match that time. Meticulous and detail oriented are a couple of my notable traits.
Becker
Would love to see after pics...
That boat pictured is no way 35 ft.
Looks like a 22-24 ft Cuddy.
8-3 for $400??? Yes double the price.
Boats are a pain in the ass, hate working in those cramped spaces.
I've passed on plenty or over bid them.
I have a 24ft cruiser, I'll be detailing it in a week or so.
X
XTREME1
I think you are over estimating how much area needs to be cleaned. I do a ton of boats and none ever takes more than an hr or two. 50' luhrs to a 28ft searay is maybe 30-45 minutes different
shadygrady
Its not so much the size/area, as the amount of detail required. I set-up and work non-stop, save for a drink of water or two. No way in H could I ever complete a job like that in your suggested timeframe. Although I wish I could.
Becker
A 50' vs a 28' is. Huge difference. I mean. If you are talking all fabrics. Beam on a 50 is greatly wider.
28' boat can have a beam of 8'-10' on avg.
50' boat normally 10-16'
My little cruiser takes me a couple of hrs to detail.
Aft cabin, V berth, carpets, fabric on walls head liner. a couple of walls.
That said. Some people clean a 3000 sq ft house in 60 mins.
Others spend 6 hrs.
We've got no room for boring.
shadygrady
I have never been a splash/dash type of cleaner, so I would probably fall into the other catagory. Whatever works.
Bruce
I cleaned a 45' Carver Sedan Bridge last week, took me 2 1/2 hours , most of the work was with my upholstery wand, no ceiling work to be done , all floor carpet. I will never clean a boat unless I'm charging by the hour.
I typically don't quote a price in advance. My instructions are usually "just do it like you always do".
Price isn't their issue.
Reactions: Bruce Humphrey
