- Joined
- Oct 6, 2006
- Messages
- 117,348
I went and HWE’d the Chapel this morning at my church. I started off wanding it but ended up using my Zipper and a back brace.I know , upholstery tool. But when i read 2000 chairs my ptsd kicked in i still can't stand straight and i only did 350
You having a Vawtism?I went and HWE’d the Chapel this morning at my church. I started off wanding it but ended up using my Zipper and a back brace.
I've been going to physical therapy for the past several weeks and ever since I've been stretching my hips, my lower back pain has almost disappeared.I went and HWE’d the Chapel this morning at my church. I started off wanding it but ended up using my Zipper and a back brace.
Do you don your chapeau whilst invigorating your flexibility?I've been going to physical therapy for the past several weeks and ever since I've been stretching my hips, my lower back pain has almost disappeared.
Easy stretches at home if you want to try it out for a few weeks
I’ve always been very pigeon toed in my walkingDo you don your chapeau whilst invigorating your flexibility?
I think it’s a good thing Jim. If I’m going to be a miserable old prick, I might as well fulfill that calling working than be at home bothering the wife.
Salt pills might help. Not a cure at your age but could give some relief.No amount of flexing, physical therapy or work outs will reverse degenerative disc disease.
Sissy!I went and HWE’d the Chapel this morning at my church. I started off wanding it but ended up using my Zipper and a back brace.
There’s an orthopedic on YouTube who stopped practicing because he says modern medicine is not about a cure but about money. He “says” there’s a way to reverse it but I’ve not looked into it.Salt pills might help. Not a cure at your age but could give some relief.
I have got rid of a lot of pain with salt but I will never heal completely. But my low back pain is gone for now. Salt pills did heel my kidneys though. I don't sweat as much much and muscles don't fatigue as fast.There’s an orthopedic on YouTube who stopped practicing because he says modern medicine is not about a cure but about money. He “says” there’s a way to reverse it but I’ve not looked into it.
A salty Lazy Boy...Find a good Chinese massage place not a hand job place
...BradyWhat kind of brace do you use Marty?
Did I say muscle spasms?What about degenerative disc disease sounds like muscle spasms to you?
It's your muscles causing the pain I bet. They tighten up and pull things together to tightly. You have to get the knots out.
It doesSure looks the same
SmokinI like the prochem tool with 1 modification i installed a modified kleanrite bypass inside the vacuum hose to keep the solution hot. the standard bypass on the tool only bypasses while spraying, i use it to control flow and my bypass modification keeps solution temperature up when tool isn't spraying
View attachment 120130 View attachment 120131 View attachment 120132
Theater seat ouch, that's some back breaking work.For trashed upholstery, you're better off with a PMF external jet and turn the pressure down. The internal jets don't have enough flow which is great on fine fabrics but is slow on trashed stuff.
