Looks like
Phoenix came out with the 300.
FEATURES:
* High capacity ? 176 pints/day @ AHAM
* High energy efficiency ? Plugs into a grounded 115-V outlet
* Pleated media filter ? Built-in air filter reduces dust and mold
* Twist-on duct collar ? Direct the drying power where you need it (collar sold seprately)
* Optional high-efficiency filter ? Removes 95% of one-micron particles
* Reservoir pump system ? Strong and dependable, 20 ft of lift
* Pump purge switch ? Drains reservoir, no spills or drips
* Pump fail warning light and cut-off ? Prevents reservoir overflow
* Lighted power switch ? Check machine status at a glance
* Digital hour meter ? Easy-to-read for more accurate billing
* 30-ft power cord ? No need for extension cords
* 30-ft drain hose ? Pump condensate to sinks or drains
SPECIFICATIONS:
* Power: 12 amps, 115 Vac, Grounded
* Water Removal
o 176 pints/day @ AHAM 80?F, 60% RH
o 304 pints/day maximum @ 90?F, 90% RH
* Blower: 540 cfm
* Drain Hose: 30 ft
* Condensate Pump: Internal, w/20? Lift
* Operating Temp Range: 33?F to 110?F
* Filters
o Standard: 20? x 20? x 4? Pleated Media 30% MERV-6
o Optional: 20? x 20? x 4? Pleated Media 95% MERV-14
* Dimensions
o Width: 29"
o Height: 46"
o Depth: 25"
o Weight: 175 lbs
Retail from $3200-$3500
