New interlink Stainless Grout Brush...Awesome!
I won this on Mikey's Board here...and had the first chance to try it last night....
Awesome little unit.
Fits and holds in the grout lines....
Took a lot of abuse and still held well after using it last night.
Just aggressive enough on this grease filled grout lines....
Got the job done and made things faster last night....
Had 4 other brushes there last night and this one was the one we ended up using
We also used CRB to try and break up the grease....but this thing was killing it for us last night.
Just had the right amount of aggressive, but not a scratching worry with the way the brushes are twirled together....and of course, this commercial kitchen tile not a worry about scratching.
THANK YOU INTERLINK AND MIKEY'S BOARD!!! :rockon: :rockon:
I am going to order a couple more! Perfect for this situation!
Here's the link to them....
http://interlinksupply.com/index.php?item_num=AB113
Son in law likes it! Aron Approved :)
One of the 2 videos done loading up.....
Great report Mark!
My cast comes off this week and I'm very much looking forward to getting to try that brush.
I think I am going to order a couple more to make sure I have them up here.....it takes a while for the pony express to deliver :)
John Olson
John Olson
You wouldn't want to use it on a white porcelain tile. Other then that if your careful it shouldn't "damage" most anything else at least not that would be noticeable.
Any mark left on porcelain should come off with Magic Als Glass and Metal Magic
kingjoelking
Doesnt that defeat the purpose of using something to speed up the process if you have to go back with other stuff and clean again?
You welcome, Mark. Glad you like it.
This is a tool develop by a carpet / tile cleaner for his own use that has been very helpful to many others.
Reactions: Mark Saiger
Have to give it a try. The one I tried market the edge of the tile. It was pretty stiff
Gene
