bob vawter
Grassy Knoller
jus starting out......
sweendogg said:Bawb.. you ever thought about making a frankenstien genie? Take off the heat exchanger and run a diesel burner or propane for extreme heat and run a completely unrrestricted the plumbing of the blower? Simply curious.
bob vawter said:Nate...yor fi would be safe......i would NEVER have an unattended fire in my van......
too many variables to consider.....
a puff of wind might blow some combustible material near yor burner?????
a gravel road might loosen a propane fitting?????
a malfunction of the burner system in any way , jeopardizes not only yor truck but the house yor cleaning AND yor whole future!!!!!
Propane is expensive!!!!
Kero makes you smell like...........kero!!!!!!
need i go on..............?
bob vawter said:i would build my world famous dual 47 blower system.....
piece a cake.........!
NO not TWO clutches....ONE good one.....A Pitts clutch is the best they make...MORE than strong enough........Johnny said:bob vawter said:i would build my world famous dual 47 blower system.....
How do you drive two 47s with an a/c clutch? Two clutches? Pics?
NO not TWO clutches....ONE good one.....A Pitts clutch is the best they make...MORE than strong enough........bob vawter said:Johnny said:[quote="bob vawter":3a4mapm7]i would build my world famous dual 47 blower system.....
bob vawter said:Larry...have i thanked you for that fi you sent me for the Tat bet......
i still got it....
i still gots the fi too.............lol!
funny....i enjoy it jus as much...each time!a few times
One of those blowers on a clutch for when you don't need to be turnin both?bob vawter said:ya the power is split at the BACK...
one pulley turning the blower forward
and the other one turns backwards....but plumbed opposite...simple!
piece a cake!
John Watson said:Jim Miller of JEM had a unit he called and sold as The Dueplex. He had 2 complete units run off one shaft. I tried one that had #5 blowers
and my blower is plumbed ezackly as Steam Genie designed it...
they spent a ton of money in the R & D of this machine and it's JUS FINE.....
right Shawn???
Mike Draper said:Do you have an unattended water heater in your house?
???joeynbgky said:Heres one for you bob.. you might be able to get a good deal on it.. looks like its not in to bad shape
WoW...that was cool....thanks.........joeynbgky said:This isnt the one i wanted to show you.. ill find the other one tonight
http://richmond.craigslist.org/cto/1980901009.html
