- Joined
- Oct 6, 2006
- Messages
- 116,883
When it does that, just change your direction of wand passes. It's the pile of the carpet. Don't fight itWhats up with chatter in the wands? My evo 13" sometimes skips around and other times glides beautifully. Seems like the weave of the carpet and the direction I'm going plays a part. Sometimes though I can't slow it down or slam it down enough to avoid the annoying skipping
I love your products Mike, but I don't think a hole glide is the best option to suggest to a new person in the business who's only wand would be the little holes. Hybrid or Slotted would be my suggestion
Then at least tell him to buy 2 glides you goober.I'm thinking that Bryce isn't a ghetto cleaner. He will dry vacuum and use TACT to his and the carpet's benefit.
No short cuts will be taken.
A Hole Glide is the cats meow for premium professionals.
ESPECIALLY for portable users
Easy there tiger, you trying to get Fred to block me if I try and sell this new guy too many things?Then at least tell him to buy 2 glides you goober.
Slotted for the ones where he can't vacuum and your glory hole glide for jobs where he has all day to clean 3 rooms like Marty
I dry vacuum masterfully the rest of it I'm not so sure aboutI'm thinking that Bryce isn't a ghetto cleaner. He will dry vacuum and use TACT to his and the carpet's benefit.
I put a Green Glide on my Evo and it is a definite improvement. I also purchased a Brushglide for it.
@Mikey P I've never actually seen a chart or comparison of the Pro's and Con's of each glide. I usually just ask you to send me which is best for the application that I'm doing.
Where the GreenGlide really shines is on my PMF Mach15. It's like a completely different wand.
I thought slot would allow for the fastest, and holed for the slowest.Slot Glides- The best choice for dirtier carpet that has debris in or on it and for cleaners who prefer some resistance or grab at the carpet to wand interface. Also, our Slots have recessed bridges so there are no lines left in the carpet when the glide is new. As the face of the Glide wears down the bridges can be recessed again with a knife, razor or Dremel tool. FYI, 80% of our Glide sales are Slots.
Hole Glides- The easiest to push and the best, cleaners with back pain, elbow, wrist, and shoulder issues and for those wanting the quickest dry times. Holes are also great for cleaning area rugs on location as the rug won’t lift up as you clean the edges and corners. Holes are the best choice for wool carpet and rugs. Dry soil removal prior to wet extraction is a must in most cases. The best choice for portable extractors too!
Hybrid Glides- Fits in between the two above, easier (some say much easier) to push than a Slot but dries slower than a Hole. Wands with large vacuum chambers such as Evolutions, SharpShooters, AW29s and the PMF “Machs” perform noticeably better with a Hybrid. Some debris can be extracted through the slot portion of the vacuum pattern, unlike our Hole pattern, but dry extraction is still recommended. This style leaves lines on some pile types and may need to be groomed after cleaning.
The old guys say the opposite to make them feel better about their weakness. Just smile and agree.I thought slot would allow for the fastest, and holed for the slowest.
Dry times?I thought slot would allow for the fastest, and holed for the slowest.
and don't tell us our shirts are inside out or that we only shaved half our faceThe old guys say the opposite to make them feel better about their weakness. Just smile and agree.
Just try to make sure you have pants on before leaving the house and not to scare any childrenand don't tell us our shirts are inside out or that we only shaved half our face
I think I'm going to need to order a slot glide for pet homes. We are firm believers in prevac, but on occasion and after a thorough vac, we still pull a lot of pet hair up with the CRB. I don't want to vac again because it's wet with prespray. Most of the time I hit it with the 2" hose, but the smaller clumps that I miss don't suck up in my wand very well.Dry times?
No, the opposite
My thinking was the bigger the opening, the more moisture pulled up.The old guys say the opposite to make them feel better about their weakness. Just smile and agree.
The old guys can't comprehend that.I think I'm going to need to order a slot glide for pet homes. We are firm believers in prevac, but on occasion and after a thorough vac, we still pull a lot of pet hair up with the CRB. I don't want to vac again because it's wet with prespray. Most of the time I hit it with the 2" hose, but the smaller clumps that I miss don't suck up in my wand very well.
