No psi pressure
WillH
Capital region carpet cleaning
I was on my 3th job (ever) with my truckmount today and the water just stopped coming out of my wand. no water pressure at the gauge. I checked the machine out and realized that my waste tank filter was full of dirt. I was wondering if anyone knew how to get the pressure back. Thanks
Your waste tank doesn't cause problems with your water flow.
Is your small mixing tank that connects to the Cat pump filling up?
If you have fresh water tanks then maybe your transfer pump isn't working and failing to fill that small tank up.
If you don't have fresh water tanks then maybe there is a valve that is shut off.
Is the pulley on the cat pump rotating-- maybe the clutch is out or the belt broke.fresh
maybe its the inline filters that are clogged.
was it below freezing in your area-- maybe you froze up your TM causing damage?
Steve Lawrence
Could be a worn or broken unloader and not a pump at all. Is there a reliable TM mechanic you can take it to?
Have you read the owners manual?--
Many don't.
This invention is fabulous at helping to avoid "headaches" and down time.
