alazo1
I've tried the following to no avail.
Disasembled the chem pump. Seals, flapper and check valves are ok
Today on Hydramasters advice changed the brass check valve on the hi psi manifold.
It seems to prime once in a while. The priming tube starts pulsing but when it goes to on the needle stays on the bottom (no sucky sucky).
Any ideas?. I put a dema valve at the exit and works ok for now but I'm sure it will be jacked up with the heat soon.
Albert
Albert
