Nuke em all and let god sort them out?
So Ron if we use a acid rinse and it leaves the carpet in an acid state does it attract more soil? And I know that some acid rinse products do leave a residue. And should we be concerned when all carpet is nothing more than a 1/2 inch of plastic?
I don't think the ph matters as much as the composition of the detergent left behind. It's just that there seems to be a mentality out there that you have to neutralize your alkaline prespray with an acid rinse. A poorly formulated acid detergent will leave as much residue as a poorly formulated alkaline detergent.
MLPW
Georgia
It makes sense that the only reason I never got callbacks for so many years was because I was just rinsing with plain water. Sure, I did an acid rinse yesterday on a job, just because there was dog urine spots. But if it was just a normal cleaning, I would've just let plain water do the job
Reactions: Papa John
Try last step it’s jim Martin approved
Loren Egland
Antioch, California
Loren Egland
And there is a lot more to cleaning performance than pH.
And some water can have a pH well over neutral, and have other impurities.
When I run out of other cleaning agents, or can’t afford to buy more, I just use water only. :hopeless: :)
Grand Rapids, MN
We have a neighboring town with a pH of 10.5 in their city water.
In my area the water will vary anywhere around 8 pH too close to 10 pH. A lot of minerals also..
it is rare that we find a neutral 7 pH in my area. But anywhere from 60 to 70 miles away over with my brothers they are in good 7 pH good quality water.
Reactions: Loren Egland
Ed Valentine
Milan, MI
Ed Valentine
BTW, one very important aspect to consider (and most do not) is the "strength" on the PH which makes the difference and not necessarily the (high or low) number. I realized this years ago when we formulated our line of cleaning agents.
I am sure, Mr. Pemberton would agree since he is one of the top Specialists in this area.
Best to all
Best to all
Ed you're saying there is more to the power of hydrogen number? I thought the number itself indicated acid or base. Logarithmic x10 up or down.
Ann Arbor
Steve Lawrence
My city pH is 6.5. Yahoo, no acid rinse needed!
Or considered.
We are not that scientific but try to do a good job for our customers.
Handing off the biz to my son in about 10 months. Hope he does well!!!!!
Ed Valentine
Milan, MI
Ed Valentine
Blue-Collar;
You stated: " I thought the number itself indicated acid or base"
Yes, the number indicates if it is acid, or, alkaline.
Regarding the PH strength, which IMHO has to be important: As an example, This is why there are average liquid Drain Cleaners, better, and best. Another example I used to demonstrate years back was to use Ammonia as an example. A bottle of Ammonia measured a certain PH.
I took an empty bottle and poured half of that Ammonia into that bottle along with half water. This measures the same PH. Then, I poured 1/4 into an empty bottle and that measured the same PH to.
Which one was stronger? Obviously, the full strength bottle!
Hope this helps.
