Nuke em all and let god sort them out?
Loren Egland
Loren Egland
Blue-Collar;
You stated: " I thought the number itself indicated acid or base"
Yes, the number indicates if it is acid, or, alkaline.
Regarding the PH strength, which IMHO has to be important: As an example, This is why there are average liquid Drain Cleaners, better, and best. Another example I used to demonstrate years back was to use Ammonia as an example. A bottle of Ammonia measured a certain PH.
I took an empty bottle and poured half of that Ammonia into that bottle along with half water. This measures the same PH. Then, I poured 1/4 into an empty bottle and that measured the same PH to.
Which one was stronger? Obviously, the full strength bottle!
Hope this helps.
Isn’t there a fellow named James Smith that teaches the same?
To complicated for cleaners to comprehend, eh?
Reactions: Hack Attack
Hack Attack
Dan
There are 7 people on a bus (7pH pure water) there are 12 waiting at the bus stop (12pH chemical) if 7 people get off the bus and 7 people get on, how many are on the bus and how many are at the bus stop?
Matt B
Matt Briseno
Powerburst in empties and com
Ultrapac Trafficlean in res (unless trashed res which will get bombed )
two of the best products for synthetic carpet in the history of the world
anyone that says different , is just stupid ...period
What do u use to rinse these to presprays ?
