Auction Odorcide, Case of 4 gallons, Fresh or Original
MB Auctions
Description:
ONE-TIME ODOR ELIMINATION
For carpet, locate the source of the odor (a black light or moisture probe may help identify urine deposits) and treat after vacuuming loose dirt and debris. Mix concentrate with water at a rate of 1:16 (8 oz per gallon) and saturate 50% beyond the actual “spot” area. For general carpet deodorizing, add Odorcide® directly to the cleaning extraction system insuring it penetrates to the odor source. Increase penetration by using a roller, hand manipulation or by “walking” the product in.
ON-GOING ODOR ELIMINATION
Dilute with water or cleaning solution at a rate of ½ oz per gallon. Apply to comm
Bid Now at CleaningClassifieds.com
** You must create a CleaningClassifieds.com account in order to bid on items. Your Mikey's Board credentials will not work. Click the following link to create your account: http://cleaningclassifieds.com/register.php **
