carpetcleaner
I have about 5000hrs on my Boxxer 421. It just started leaking oil. It was leaking from the breather hose that connects the valve cover to the air filter housing, so I replaced it. I also replaced the valve cover gaskets and the "o" ring on the valve cover that splits for the breather. There is oil still leaking from the valve cover breather hose, right at the air cleaner housing. The new hose fits really tight and doesn't seem like it should be leaking.
There is a lot of oil leaking, way more than it seems should be coming from that breather hose. There is enough oil inside of the air cleaner housing to cause oil to leak out of it. Anyone know what I should check?
