My apologies if they come out to big...havent quiet figured it all out yet
The nasty engine side heat exchanger...damn exhaust under was all plugged causing massive back pressure..thus my exahust leak...that was the main problem....changing airfilters every 3-4 jobs is a pain in the ass if you are wondering...
the exchanger cut out...see where after we cut it just fell apart....see the little elbow on the left...yeah that fell off the night before while i was checking for clogs....
Massive plumbing clean out...that "T" was where i was having the issue...put a 01 jet inside mix tank to give the back pressure i needed ...see the weld job they did for me..not "pretty" but works, going from 1" exhaust to 1.5"
little closer of plumbing.....I really should have done a before and after...
picture a 4 way and a 3 way brass fittings...2 extra hoses, the valve for the bypass...2 thermo stats (yeah 2 one for actual temp and 1 was for the bypass, which hasnt worked for ohhhh a year)
put the muffler where the exchanger was..now need to vent through floor...not the prettiest of the show..but it works pretty good now..
oh yeah had some electrical issues tonight on my test run at home...arggg i was pissed..but its fixed and runs nice and smooth
